Why isn't my tablet working
My tablet wont come on
Is dit een goede vraag?
There may be a problem with the battery or charger, check out the Troubleshooting Guide for more information.
Was dit antwoord nuttig?
Have you tried charging the battery? If you plug in the tablet but the battery won't charge, the battery adapter may be broken. If so, try using a different battery adapter and see if that works. If you have exhausted these options and the tablet still does not turn on, then the problem may be with the tablet itself. In that case, you could try replacing the battery in the tablet because it may have run out of juice.
The Reason Is Probably Because It Needs To Be Restarted.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 364
3 opmerkingen
What have you tried? Charged it? New charger;new cable?
door oldturkey03
Can you try to describe your problem in detail? What is the situation of your tablet now?
door William
My touch isn't working at all. Power and volume buttons are but no touch???? WATS wrong
door zionwh123
