Ga door naar hoofdinhoud
In augustus 2000 werd de negende generatie Corolla geïntroduceerd in Japan, met een scherper design en meer technologie om de modelnaam de 21e eeuw in te loodsen.
The horn does not work
the horn does not work
Is dit een goede vraag?
Score 3
2 opmerkingen
fuse is not blown but horn still does not work
door
what else could possibly wrong with the horn
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Sam Mazzolino, could be a horn issue as well as a blown fuse, the horn relay or even the horn button itself. First check the fuse. Make sure that it is good. Then apply 12 volts to the horn directly and listen if it works. Some instructions on here If it does, you know you are having a power issue. Check the relay next. For more information about the relay location etc. We'd need to have the exact year of your Corolla.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
my car is 2006 toyota corolla
door
I normaly only work on domestic autos however this is simple. Check your owners manule for the locations of all fuse banks. Next look for any fuse related to your horn. Check each one for a bowen fuse(burnt center seperated metal strip). Replace with like fuse I.E. 20 with 20. Note do not replace with greater or lesser fuse, you will damage your electrical system. If all is well an no horn then compleatly disconect the batery for three minuts an reconect snug. If still no horn run a code reader to see if the car tosses a horn code. If no horn, fuse problem, and or code take it to a Toyota delership, this should be fixed for free or up to no more than $199.00. I know you should go directly to a code reader however not all of us are rich enuf to buy one or to go right to the dealer. This is the best way to go about any auto problem before flushing away your bank acount. I hope this helps.
Score 1
My Toyota Corolla verso diesel 2008 car's horn is not working please tell me how I can fix it myself. Thanks
If the fuse is good and the horn it self is good, then it should be from the horn and srs connection under steering
Voeg je antwoord toe
Sam Mazzolino zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 51
Altijd: 21,570
