Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
polarity battery iPhone 6
Hello. My battery is dead and I can not start charging.
I want to revive a power supply.
What is the polarity of the battery?
Thank you.
Update (10/25/2015)
Hello.
I've already found.
I share a picture that lets you know the polarity.
The picture is based the motherboard
Thanks.
Is dit een goede vraag?
Score 2
2 opmerkingen
By the way.
I made a direct connection to the battery with a charging power supply and has awakened.
The battery fell asleep for being two months without turning on the phone and had 90% load. Very strange.
A electrosock and everything works. :)
door
Could you help me? So + is the connector closer to the battery?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sergio, post a good image of your battery connector with your question. Use this guide for that. It will allow to mark the contacts for you. The positive and negative connectors are the left and right outside connectors. The concern that I have with that, is why you have to do that. Obviously you are having some issues with your phone which you should consider repairing first.
Was dit antwoord nuttig?
Voeg je antwoord toe
Sergio zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 82
Altijd: 17,493
