Ga door naar hoofdinhoud
De Macintosh Powerbook 140 was een vroege laptopcomputer van Apple. Hij beschikt over een grote voedingskabel, een accu, een trackball in plaats van een trackpad, was een van de eerste Apple-computers die een interne diskettestation gebruikte en heeft een in hoogte verstelbaar toetsenbord. Het was tevens de eerste laptop met een toetsenbord aan de achterzijde van de computerunit.
How do I fix my screen?
Hello. If anyone knows about older Apple computers, I need your help. I recently got an old Macintosh Powerbook 140. I have plugged it in, and when I power it on, I hear the startup sound, and the speakers emit a tone, but the screen displays nothing. I have checked for any visible damage, and there appears to be none. It may be of note that the computer hasn't been used at all for the past 20 years. I do know that the last report of its use was that the screen was a bit touchy. 20 years ago, the screen could only be seen from the correct angle, but now there is nothing. Can anyone help?
I should also note that I have little experience with physical electronics. I work well with technical stuff, but I only have a basic understanding of electronic terms. If you could explain and terms for me, that would be great.
Is dit een goede vraag?
Score 1
1 Opmerking
Update: I have been getting tiny lines of light on the display for just a few seconds. not sure if it means anything but I thought it might be good to know.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sounds like a bad inverter. Move the screen back an forth and seem if you can discern anything on the screen.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
I can't see anything on the screen when I tilt it or look from a different angle. i do however know that when it was last used, this solution worked, but it doesn't now.
door
Proceed as Apple suggest:" No display, but computer appears to operate correctly.
1 Adjust screen contrast.
2 Check display cable, inverter board, interconnect board, daughterboard, and motherboard connections.
3 Replace inverter board.
4 Replace interconnect board.
5 Add shim to display cable. Refer to Additional Procedures.
6 Replace power cable.
7 Replace display cable.
8 Replace FSTN display (all repairers) or replace activematrix
display (CPRC/ international repairers only).
9 Replace daughterboard.
10 Replace motherboard.
door
Ok. Could you explain some of the terms for me? I'm not great with the technical terminology. Also, I only have one external cable. It's the power cable. Should I have more?
door
hello
very common failure in these machines : LCD caps and inverter caps are gone , must recap lcd screen and inverter with new capacitors , i solved this problem with all my powerbooks 140-145b-160
see this video :https://www.youtube.com/watch?v=XP-fWaDb...
Score 2
Voeg je antwoord toe
Jack zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 3,059
