Why wont anything come on monitor screen?
Both the tower and monitor have power to them. Vable connected between them properly, yet the monitor does not show anything
Is dit een goede vraag?
Sam I Am,
Start trubleshoot from monitor
if the monitor working,
you should begin to troubleshoot the PC
Here you can find the Video card replacement guide. you can remove the video card and clean the card and motherboard interfaces and reinstall video card and check whether PC video out works fine
if above steps not help to solve you issue or if you PC run with on board graphic controller you can remove RAMs and clean the interfaces and reinstall RAMs properlly. and check whether vedio out start to work back
Here you can find RAM replacement guide,
Cheers!
Handleiding
Moeilijkheid:
Eenvoudig
5 - 10 minutes
Handleiding
Moeilijkheid:
Eenvoudig
10 minutes
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 1,488
