Ga door naar hoofdinhoud
Mid-range desktop PC made by Dell. Model number 4600.
8 Vragen Bekijk alle
Why wont anything come on monitor screen?
Both the tower and monitor have power to them. Vable connected between them properly, yet the monitor does not show anything
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sam I Am,
Start trubleshoot from monitor
  • Connect it to laptop or any other supported video output to check wheter monitor is works fine
if the monitor working,
you should begin to troubleshoot the PC
Here you can find the Video card replacement guide. you can remove the video card and clean the card and motherboard interfaces and reinstall video card and check whether PC video out works fine
if above steps not help to solve you issue or if you PC run with on board graphic controller you can remove RAMs and clean the interfaces and reinstall RAMs properlly. and check whether vedio out start to work back
Here you can find RAM replacement guide,
Cheers!
Dell Dimension 4600 Video Card Afbeelding
Handleiding
Dell Dimension 4600 Video Card Replacement
Moeilijkheid:
Eenvoudig
5 - 10 minutes
Dell Dimension 4600 RAM Afbeelding
Handleiding
Dell Dimension 4600 RAM Replacement
Moeilijkheid:
Eenvoudig
10 minutes
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sam I Am zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 1,487
