Ga door naar hoofdinhoud
Dell Dimension 4600 Video Card Replacement
Wat je nodig hebt
  1. Dell Dimension 4600 Video Card Replacement, Side Panel: stap 1, afbeelding 1 van 1
    • Locate the case cover latch on the back of the computer.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Dimension 4600 Video Card Replacement: stap 2, afbeelding 1 van 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Dimension 4600 Video Card Replacement: stap 3, afbeelding 1 van 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Dimension 4600 Video Card Replacement, Video Card: stap 4, afbeelding 1 van 1
    • Lay the computer flat so that you are looking down on all of the components.
    Vraag FixBot
    Voeg opmerking toe
  5. Dell Dimension 4600 Video Card Replacement: stap 5, afbeelding 1 van 1
    • Locate the Video Card and the screw attached to the Video Card as shown in the picture.
    Vraag FixBot
    Voeg opmerking toe
  6. Dell Dimension 4600 Video Card Replacement: stap 6, afbeelding 1 van 1
    • Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
    Vraag FixBot
    Voeg opmerking toe
  7. Dell Dimension 4600 Video Card Replacement: stap 7, afbeelding 1 van 1
    • Push down on the green clip located by the bottom right corner of the video card while simultaneously pulling the card up with your other hand.
    Vraag FixBot
    Voeg opmerking toe
  8. Dell Dimension 4600 Video Card Replacement: stap 8, afbeelding 1 van 1
    • Pull the remainder of the card up and out of it's slot.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Arvind
395 Reputatie
2 handleidingen geschreven
Cal Poly, Team 6-10, Regan Fall 2011 Lid van Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Leden
11 handleidingen geschreven
2Gids Commentaar
I have a question - My dell dimension 4600 has lines going down the screen, ive tried 3 different monitors, reinstalling windows (reinstalling would have lines going down the screen, after installing all programs the system freezes up with lines going down the screen nothing else) ive tried system restore can someone tell me whats going on?
Don't hurt the chickens - Antwoord Deel
That sounds like either a GPU failure or internal Graphics failure. Have you checked thermal paste?
William Morgan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 8,165
