Ga door naar hoofdinhoud
The Huawei Ascend P7 is a 5" smartphone released by Huawei in June of 2014. Model numbers: P7-L10, P7-L00.
Why is my phone switching on and off by itself?
For no reason my phone just starting to switch on and off repeatedly. It was working fine the one minute and the next minute just switched off and then on again. It stays on for about 5 seconds and then turns off again and then on again. And so it keeps repeating the process.
I tried restarting, and tried power off with no success. I then took the SD card out but the phone keeps doing the same. When I remove the SIM card then it stops switching on and off, so it seems that the problem is with the SIM card. Is that even possible?
Please advice urgently if there is anything that I can do.
Is dit een goede vraag?
Score 49
25 opmerkingen
i have this problem too
door
Dear your support i have huawei P-7 Why is my phone switching on and off by itself?
door
Am apparently facing the same problem my Huawei P7 mini
keeps restarting even after a hard reset
door
My hauwei p smart also switching off and on itself.. Many time, i dont no what happen.. Can you tell what im going to do
door
My huawei nova 2 lite doing it too it's making me pist off
door
20 commentaren meer tonen
Voeg een opmerking toe
27 Antwoorden
Het nuttigste antwoord
Guys,
I had the same problem too. I took it to the Huawei authorised repair centre. They had the phone for few days to find out that the vibrator was faulty.
Occasionally when the phone vibrates, it resulted in an internal short circuit which ended up rebooting the phone. If the phone vibrates while rebooting, it goes back to restart mode again. They replaced the vibrator at free of cost.
Now I am one happy HUAWEI customer.
Hope this helps
Note: According to them, any internal damage could result in continuous reboot.
Was dit antwoord nuttig?
Score 8
1 Opmerking:
I have same this problem . Why??my mobile is huawei honor 10i
door
Huawei is on off buy itself
Score 7
1 Opmerking:
honor 10 lite my phone suddenly turn offed dnno y still know its not opened
door
my cell phone was in a proper condition but after some while the cell switched off automatically and was not getting on i tried each and every step for switching on my cell but i was fail in my each step....so please help me with my problem what should i do for it...
Score 6
8 opmerkingen:
ano prob ng cp po pg on and off lng xia paulit ulit ,unit ng cp huwei che2 L11,tnx po
door
Same to you,huawei Kll-L22 on and off repeatedly. What. Should I do? Tnx for help
door
Huawei is the worse company ever, these people should be banned immediately and permanently from making products, they are total failures and it’s the last time i will ever use any of their products again. Very disappointing..
door
I regret ever using such useless prroduct
door
In 2025 this stupid company still failed to produce a standard products. Useless!!!
door
3 commentaren meer tonen
Did you do a complete reset? Sometimes it does the trick. And it reads a bit like the power button is stuck. Maybe it doesn't feel that way but if it is only a bit stuck it still thinks it has to reset.
Or water damage?
Score 5
4 opmerkingen:
my huawei y5 2018 is getting on and off automatically ..what is the problem..
door
My phone huawei y7 prime 2018 gets switched off automatically..
door
door
30/11/2020
door
iam gonna try this now, but my problem is i was typing something and i went off by itself, so i tough it was stuck so i let it reboot itself. but as soon as i wanted to type my simcode in it went off agian and it keeps happening. did someone had this same problem or not?
Score 4
2 opmerkingen:
i had that problem i had to download a new keyboard off the play store by using the google voice keyboard
door
I'm having this problem too
door
contact me on
affosaalah@gmail.com for huawei on and off solution .
whatsapp number 00233262093338
i am gsm engeneer.
Score 2
Score 1
1 Opmerking:
My phone has a problem I don't know what to do I switched off mistakingly and it has never turned on since then I keep on repeating and repeating again to press the power button but it won't turn on
door
i believe my phone is on drugs nowadays Huawei Y330 it shutdown and when i try to switch it on, it doesnt show up... the same happens when i update my facebook app.. once i open FB the phone goes off immediately. i have to take off my battery thats when it can power ON.
Same here when the battery reaches10% it flashes on for 5seconds and then off and repeats itself till my phone died. My wife has an identical phone, both a week old and hers is fine..Wtf
2 opmerkingen:
mine would be at 100 and turn off completely even when i have it on a charger.
door
mine is the same
door
Hello, my huawei turning of itself , i went to repaierer and he change turning buttom but it still doing same and if i do factory rest it helps?
1 Opmerking:
They are very shameless company that deserves to be taken out from the history of gadgets production they failed their all customers..
door
My battery just shut down.Itry to put in a new battery,but the phone is just blinking. The battery I took out seems like it was swollen.
For no reason my phone (Huawei Y7 Pro 2019) just starting to switch on and off repeatedly. It was working fine the one minute and the next minute just switched off and then on again. It stays on for about 5 seconds and then turns off again and then on again. And so it keeps repeating the process. I was just watching videos at youtube.
5 opmerkingen:
Mine is doing the exact same thing but after i have taken out the sim cards and the SD card it still doesnt come on
door
Mine was okay now. Thanks to the technician from the Huawei Center.
door
It switch its self off when um on the phone call
door
how many days does it take to be repair?
door
my phine is fully charged keeps getting hot also ...then switches off getting annoted with it no water damage or dropped it just started doing it on own any advice ??
door
I have the same issue… this started about 6 hours ago
1 Opmerking:
Huawel should be banned! It’s the worst thing that happened to the world tech…
door
I've been having the same problem tryed reseting the phone putting it into safe mode none of it worked, I haven had it long so there was no way it was damaged in any way it was definitely a software fault but I managed to find the fault by luck not brains. All I did was change the theme it must have been crashing the phone somehow.
1 Opmerking:
Exactly what I did sometime ago. I change it to the default theme and it started working again now am having the same problem again and just when I switched the theme it went off... Am beginning to think that's its centered on the theme
door
You might want to go to settings -advanced-then backup and reset and youll find the reset settings option then you want to click on it and wait and it will restart all your settings
No data will be deleted
Hope this helped also im 12 UwU
Try a hand flush. If you still having the problem then you should visit a customer center.
It might hardware problem.
3 opmerkingen:
what is a hand flush?
door
It means hard reset. Please check this video, hope this might help you.
https://www.youtube.com/watch?v=eTX-JYBS...
door
I did that several times but it only work for 1 or 2 days then it reverts back to that norm
door
My mom has this problem too on her Huawei P9 lite
Take it for repair.. Sometimes it might be the Circuit… and beware of using the Blackberry Charger on Huawei… I had the same only to find out that the charging system and the Camera Circuit were burnt beyond repair.
It doesn’t need factory reset rather take it to repairing proffesionals!!
I cannot tum on or off. The screen keeps flashing constantly on and off all by itself. I tried charging it but it hasn’t worked. I do not know how to open the phone from the back to check on the SIM card. Can you advise me what to do /
1 Opmerking:
I am having same problem when it being running switch off itself. How to solve this problem?
door
I have the same problem and I went to the service center of Huawei.
1st method is they reprogram my phone it was okay for 2 days and the problem returned so the 2nd method is to change the main board which took me 2 weeks to wait because they have to order it from the main store and the changing of main board took 2 hours. So far my phone is okay now and the new main board has 3 months warranty.
Total payment is almost 30USD
Mine was fixed in the end by replacing the battery...it had got old and stopped holding its charge, and although it wasn't running out completely, my phone kept rebooting itself as if it had.
I had the same problem did a complete reset. Didn't help. Noticed when WhatsApp message came in the problem started again. Deleted WhatsApp without backup and reinstalled. Phone perfect now.
My mobile automatically switch off and switch on why too much time coming this problem
Please tell me how to solving Please
You must change the better
I’m actually facing the same issue with my Huawei phone, where it keeps turning on and off by itself. I’ve found that it could be due to a few reasons. For me, it seems like the battery might be the problem because when it’s low, the phone shuts off randomly. Overheating is another thing I noticed—if I use the phone for too long, it tends to turn off to cool down. I also tried restarting in safe mode to see if it was an app causing the issue, but no luck yet. I’m thinking of taking it in for a check-up if it doesn’t improve. Hopefully, it’s something simple!
My honor phone of itself
How to fix a Huawei phone when it's overheated the screen is broken how can I fix it without using any two only reason only tools
Voeg je antwoord toe
cbailey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 117
Altijd: 99,385
