battery showing low temperature.
Recently I had purchase samsung galaxy j1 on 30th aug 2015 & just few days back the battery showing low temperature what does it means....
Is dit een goede vraag?
arindam bose, this is a pretty new phone and I would suggest that you have it fixed under warranty. The usual causes for this error are issues with the battery connector, failed btemp line on the circuit board, bad battery, bad charging port flex. So if I would fix it outside the warranty (bad idea) I'd start with a new charger, then a new battery, then do some fault finding on your logic board. Again, use your warranty.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 2,140
1 Opmerking
je restées charge a long temps que afficheur
door cettefilleestmahboula159
