Ga door naar hoofdinhoud
24"-display; ingebouwde iSight-camera, microfoon en luidsprekers; resolutie van 1920x1200. Uitgebracht in oktober 2008, te identificeren aan modelnummer A1267.
Common Logic board burn spot?
Hello
My cinema display started smelling weird and then shut down. I opened it and found the problem to be a burned spot on the logic board. No problem I'll just replace the logic board and then I can use it again.
So I was browsing for a new board when I saw a dutch thread with someones logic board also burned. But the weird thing is that the burn is at the exact same place.
Afbeelding
Does anyone have had a problem with a burned board?
Is dit een goede vraag?
Score 4
2 opmerkingen:
Lukas Guy, it might help if you add some images to your question. That will allow everybody to see where the board gets damaged
door
Hi Lukas Guy, I have a Apple Cinema with probably the same issue. How did you replace this part? Where can i buy this part?
Gr. Vincent (from Holland as well)
door
Voeg een opmerking toe
1 Antwoord
Lukas Guy, that looks like the LED driver. It is most likely a "common" failure if you have a short within the backlight circuitry. Any short there would take out that driver. I would suspect the primary offender would be the LCD connector.
Was dit antwoord nuttig?
Voeg je antwoord toe
Lukas Guy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 2,807
