Ga door naar hoofdinhoud
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Vragen Bekijk alle
Blew up, getting spark from motherboard, whats blown up?
Hi!
Not sure if I have spilt something on my MacBook Pro, but a few days ago it turned off with a small puff of smoke, and the motherboard has some damage, pictured, is this repairable does anyone think?
Also when I did plug my power adapter in while case was open, there was a mini spark from that point again.
Any help would be great!
Is dit een goede vraag?
Score 2
1 Opmerking
You're talking about the damage in the mid right side of the picture, yes?
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Cameron Lewis, looks like your board is a 820-3115. The component in question is U9410 which is CD3210A0RGP current-limited power mux. Now, if you do a Google search for CD3210AORGP you'll find a few places like this where you can buy this IC. It is an LGA IC and as such will or course require good skills and tools to resolder. From what I can see on your image, it appears that you shorted out pin 6 or pin 7 (hard to see and consider posting a close up image)of this IC and damaged the trace to the capacitor right beneath it. Anytime you shortened out a component, Please remember that your board may also have a short circuit in other components.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Nice answer!
door
It is a very open ended question. Mother board repair is not a simple component swap and you are done. There are a lot of measurements you need to take in order to know what's up. It also sounds like you have not made any measurements or checked the schematics...
UPDATE (09/05/15)
After closely looking at the picture I realized there was actual damage on the board instead of being a stock picture or what not...
1. That chip is part of the 3.3 V main line.
2. OldTurkey is correct. That is the chip you are looking for.
3. Now shift your focus to the capacitor right under the chip on the left side. The diagram has it as C9410 for your reference. These are the specs: 0.1uf 10% 50v 603-1. That is most likely the cause of that chip blowing up.
When a capacitor fails you will get a straight wire which will short your chip to ground. This voltage is more than the desired burning your components and most likely in this case there might be some board repair on the paths and traces underneath.
This is repairable. You can mail it in to someone who can do the job OR you can try to do it yourself if you have the right tools and experience. If you decide to give it a short let me know and Ill be happy to give you some pointers :)
Score 1
4 opmerkingen:
Do you have schematics available or a suggestion for what measurements he should take?
door
Israel, this is not an answer. You can do much better. Go stand in the corner till you're ready to do something besides lament.
door
Dang it I don't like to be in the corner :)
door
Nice update, you can now leave the corner and go play, good boy! Have a cookie.
door
Just by looking at that picture, the main damage is obvious - it also looks like it took out a few nearby components.
I don't have a schematic - I don't know of any out there for these.... if anyone here does, I'm sure they'll point you in the right direction.
Personally, I think your mac is dead. It has some value left there in at least the screen.
If you could find out what the components are, and could change them.... it MAY work.... but, like you say, you're not really sure what even caused the original problem. Was something split on it? if you replaced those with obvious damage, and powered it on, would you just burn them out again?
Giving the board a proper inspection may reveal more clues, but on the face of what you have here, as a repair shop, I would not want to waste my time. The only feasible repair at this point, would be a full motherboard replacement..... but you would have to weigh up the cost of that, vs selling your damaged unit, and buying a working second hand, or splash the cash and get a new one (slightly discounted by selling the faulty one)
hello everyone, I have the same problem and I would like to know if the damage to that component affects the mini displayport (thunderbolt) connection
2 opmerkingen:
@jamesoconner - Sure it’s possible as this is a power MUX in this case, and your board could have other damage.
So just like a doctor, one needs to diagnose the patient not your friend as he could have a different issue even if the symptoms are the same (or even different)!
Best to open the system and make a full detailed inspection. Do you see any liquid or corrosion damage? Do you see any stained or puffed up components?
Reference this guide to take the logic board out and use the images as what yours should look like MacBook Pro 13" Unibody Late 2011 Logic Board Replacement
door
@jamesoconner what are the issues you are experiencing with your mini displayport (thunderbolt) connection?
door
Voeg je antwoord toe
Cameron Lewis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 7
Altijd: 756
