Not charging htc m8
My phone will not charge no matter what charger i use.
Is dit een goede vraag?
There could be several things that could cause this issue.
Do you see any indication that the phone recognizes that it is plugged into a charger? Does the charge led come on when plugged into a charger? Does the screen display any type of a battery symbol when plugged into a charger? Does a PC recognize the phone when plugged in? If the answer is no to all these questions then you likely have a faulty USB charge port on the phone and may need to replace it or possibly just clean it.
If the phone does show a battery logo on the screen with an exclamation point inside it then this means the battery is not communicating properly with the device. This can be caused from a poor connection to the motherboard or battery or from a faulty battery. Check the battery's connection to the motherboard and make sure there is no damage to the cable such as a tear. Try reseating the connection to the motherboard if the cable appears undamaged.
Has the phone been exposed to water or any liquid? If so the battery was likely damaged and would need replaced. You will also need to properly clean the phone which if this is the case reply back and mention it has water damage and myself or someone else can explain how to properly clean the phone.
Do you often let the battery discharge to the point it shuts the phone off due to a low battery? If the answer is yes then trying what aebelcarris mentions in his post may help solve the issue. Li-ion batteries do not like to be discharged or overcharged. Doing so will likely decrease the battery's lifetime and can also cause issues like this. There is a built in circuit that helps protect the battery from overcharging, discharging, and more. If the protection mode is activated it puts the battery in a sleep like state. At this point it will not respond to a normal charger and will require a boost charge which supplies the battery with a higher voltage for a short period of time. This helps wake the battery. Once it wakes then it can then be charged with the original charger.
There could be more possible reasons the battery won't charge but I just listed the more common issues I have experienced with the HTC one.
Was dit antwoord nuttig?
Just had this happen on my m9. Dropped my phone in the pool.. not sure how to clean it fully? I guess i need a battery replacement as well. Let the phone in oatmeal then rice as i read online. Whether it helped or not i dont know but for sure things seem to improve as i nowbhave the battery icon with exclamation. The phone is also very hot when plugged in and I actually got it to power up all the way..then i powered it down to let it charge more. However cant seem to get it charged fully and the phone continues to run hot
Yes. My phone shows a battery logo with an exclamation inside. What should i do?
My phone shows a battery logo with a flash inside. The LED lamp is also blinking amber, but it won't progress on the charge and turn on (been on charge for 1.5h). Any ideas? Background: I opened it up to check for lose connections in my camera. it had water damage in March but was fixed and working fine. I've double checked the battery connection on the motherboard. Have calibrated battery by holding down volume & power button for 2mins). Any other ideas?
this is a common problem actually with kindles and also other phones. one solution is to hold down the power button for 30 seconds while the charger is plugged in. turning it on this way. sometimes you can also do this while the phone is off of the charger. sometimes you have to power it on holding the power button and the volume either up or down button, different phone combination. I hope that this helps you out and that your phone starts charging
Also something that happens with me often is background apps that are ruining which consume a lot of power. There are apps that will hibernate then and boost your phone charge. The app i use is cm cleaner. Really helped yup charge many phone faster and extend battery life. When my phone won't charge i use this app and normally it works
my phone is coming up with battery when chargers connecting n has a flashing light but aint turning on or anything?> please help
had creaming soda spilt over it and that was few months ago then just stoped working then i had it working again and nothing.
I usually give a massage to my battery and replug charger. Then the charging sign will appear.
This is because the m8 it's self has too much HTC JUNK IN IT , (dot view).( Mirror link) HTC clock) and so on , then there's google clock google weather HTC weather , and so on , could try this see if it works it did for a week with me , them bang of the wall.
1) power of device completely
2) press and hold volume down while pressing and releasing power button ,
3) Then down to recover using volume keys
Straight after pressing recovery option press and hold both volume up and power once you see the animation of red phone release only the power button ,
4) Then go down to clear catch ,
5) Finally reboot.
Once done this if not working , hook up to windows desktop computer sit back and let the computer check install drivers and scan device for faults , either using (windows recovery tool preferred) or iTunes
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 28,878
1 Opmerking
My phone jumped, unaided, into the sink of dishes I was washing. I powered it down immediately and stuck it in rice. It turned it's self back on some time later, took a charge even, but now isn't charging. Being plugged in is keeping it on and at 3%. Anything I can do to save it?
door Monica Foster
