Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Vraag afgerond
Dead iPhone after going in pool
Hi guys,
I have an iPhone 6 that went into the pool about 2 weeks ago. Put in a bag of rice and other tricks but it is still dead. Looking for ideas of what can be bad, how to test or troubleshoot different components.
Thank you for your help.
Kevin
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
First off, the whole rice thing is a myth, it does absolutely nothing. If you're looking for what you can do yourself, the best thing is to open the device, remove the motherboard, and use some alcohol and a brush to clean up the board and remove all the corrosion.
If you have a soldering iron or hot air station, you can remove the shields on the motherboard, and clean in those areas too. If you want to give it the best chance of working again, take it to someone that will remove the shields and run it through a professional wave frequency ultrasonic cleaner.
Was dit antwoord nuttig?
1 Opmerking:
I plan on opening it up tomorrow. I'll let you know how it turns out. Thanks for the info.
Kevin
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 104
