starting issue, battery good, makes noise but no start, ideas? Randy
206 vespa, 900 miles, no start and battery tested good, just makes a noise but no start< Randy
Is dit een goede vraag?
hi
1st check your fuel system if it feeds correctly and make sure the carburators are clean
2nd check your high tension wires if it does fire up your spark plugs
hope it helps
Was dit antwoord nuttig?
i bet the noise your hearing is from the starter when it try to start the engine.
Starter Bering's locks or neutral safety switch is bad
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 384
You'll need to provide a lot more information, there are many things that can prevent it from starting. What model of Vespa? You are saying the starter is not turning the motor over? or the motor is turning but not firing? Is the noise a clicking or a whirring noise?
door Eric Essen
rappinrandy , what noise does it make? What have you checked?
door oldturkey03
RE: 2001 Vespa 150 CC
My Vespa has been on a battery tender almost a year and I have started it up with no problem. This morning, it would not turn over. Has gas though it is old. Has oil but again, it’s old.
Any suggestions / remedies?
Thank you,
door Liz Lopez
