Ga door naar hoofdinhoud
De HP Chromebook 14 is een variant van de Google Chromebook-lijn die op 11 september 2013 is uitgebracht. Het modelnummer is 14-Q010DX.
Battery replacement - will this fix the problem?
This Chromebook battery will not charge (stuck at 12%). "battery_test 1" indicates battery is good. I am concerned if I spend $75 on a replacement battery on a $200 Chromebook it still may not fix the problem. Is this a known issue that is easily fixed with battery swap? If so, I might continue with the purchase. Model: 14-q063cl
Is dit een goede vraag?
1 Opmerking
If the laptop is out of warranty you are right to be concerned about the cost. My personal opinion is to offload the faulty laptop and buy a new one. Chromebooks are so cheap nowadays one COULD just buy a new one every time it fails when it is out of warranty.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Just an idea. If the test indicates “good” try carefully disconnecting the battery and discharging power by holding down the power button for 30 seconds and then reconnect and switch on. Any help?
How to disconnect battery:
HP Chromebook 14-Q010DX batterij vervangen
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Kurt Dreher zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 440
