Ga door naar hoofdinhoud
Een e-reader met aanraakscherm van Amazon met stille knoppen voor pagina-omslaan en automatische achtergrondverlichting, uitgebracht op 21 oktober 2014.
How do I disable the light?
Is it possible to disable the light by removing the light censor ? and can i do it without doing any additonel damage ?
I so much want to get rid of that light.
Is dit een goede vraag?
2 opmerkingen:
Have you gone to settings and decreased the screen brightness to 0 and disabled auto brightness?
door
Yes I have. From my research the kindle paperwhite and voyage is not made to be completely turned of lightwise. You can set it to minimum but you can still see it in dark rooms. Don't know why. The only time there are no light is when using screensaver. Ty for fast reply.
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
If someone can find out how the light is working on the electronic end they can just reverse engineer it and find the solution, in the community there is two methods one is jailbreaking and using a custom firmware to do this the other is using the ~ds on search bar and using a magnet to the cover magnetic locking point, but this method has a fall back the screen cannot be locked, you will have to hold power button 7 second and choose screen off, to revert back to normal just restarted the kindle
Was dit antwoord nuttig?
Voeg je antwoord toe
Beck zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 21
Altijd: 1,008
