Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Nintendo DS Lite werd in 2006 uitgebracht als de opvolger van de Nintendo DS. Het openen van dit apparaat is eenvoudig, wat reparaties makkelijk maakt.
How fix bent something inside card reader?
I watched inside card reader.
then I saw bent something.(just one)
Is that not right?
Everything staight up to bottom
but just one is left to right.
Do I have to replace or remove it?
Thank you!
I'm waiting for answer :-)
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Gekozen oplossing
if you know how to solder. you can replace it with this..
http://www.dealextreme.com/details.dx/sk...
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thank you. It will help for me.
door Deel
ok, i have to accept that you changed your mind and accepted his answer.....
door Deel
Het nuttigste antwoord
ok, i was right.
it was not necessary to open a new question for that. but you can close the othere one by accepting the answer there.
the card readers are very weak - surely you could try to bend the wire back - but it will most likely break.
replacing the card reader is the only real fix for that
Score 2
1 Opmerking:
Yes, you're right! :-)
I'm gonna replacing the card reader.
Thank you for answer.
door Deel
I have a scan disk card as it was inserted into a card reader it was bent right in the middle. Can the data be recovered from it...it has several pictures and video on it?
1 Opmerking:
Stephanie, you will get much better help if you ask your own question and not tag it on as an answer to an old question. When you ask your question you should also give more info. Like the type of the card and where is it bend etc. Good luck
door Deel
I watched inside card reader.EverytDo I have to replace or remove it?hing staight up to bottomThank you I'm waiting for answer
Voeg je antwoord toe
Taeyeon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 6,109
