Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Phone overheating when camera is on
Hi,
I have a problem with my iPhone 5s. I dropped my iPhone and the screen was cracked. After the drop, my rear camera and flashlight stopped working. I thought if I replace the screen, the camera might start working again but no luck. If I try to turn them on, the top right corner of the phone gets extremely hot and I need to turn my phone off to stop the heat.
Anyone know what might be the problem and how to resolve that?
Thank you.
K.V
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Sometimes on electronics the thermal paste can get dried up. Sometimes it's best to open it up, re-paste the thermal, and put it back together. Although what i think is happening is the camera is stuck on permanently and that is causing the heat ups. Hope that helps!
The camera part on ebay is about 10$.
Was dit antwoord nuttig?
1 Opmerking:
Thanks for your reply. The flashlight is also not working. Do you think when I replace my rear camera, then it all should be OK?
door
The camera and the flash light are correlated parts. If camera stops working, the flashlight doesn't work either. Therefore, fixing camera issue resolves the flash light. You can get the required part here. Check out similar vendors selling the same items at the most competitive price. This will benefit you.
Voeg je antwoord toe
Keiro Vantsi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,664
