Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Replacement screen has Vertical Gray Lines
Just replaced my wife's iPhone 6 screen with one from iFixit and it has vertical gray lines. I tried reseating the cables. No dice. Tried unplugging battery for 30 seconds. Checked connectors for bent pins. Don't see any.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
This is normally because of a pinch in the ribbon cable that has damaged data lines or the LCD cable was flexed at the LCD and broke connections.
I have also seen this in rare occasions if the digitizer cable is not properly seated.
Was dit antwoord nuttig?
2 opmerkingen:
thanks for your reply.. so does that mean this digitizer is hosed and i need a new one?
door
I just had that issue when I was replacing my screen and found the problem to be one of the connectors from the digitizer not being properly seated.
door
Either the above answer by chriswku03, or it's because the units enclosure is bent out of shape.
It is a pretty thin piece of aluminum after all, so it doesn't take a whole lot before its bent, especially if dropped.
I plugged in the original cracked one and it worked fine. iFixit sent me a new unit that works perfectly. Great customer service!
Voeg je antwoord toe
timktran zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,341
