Ga door naar hoofdinhoud
The Samsung HLM or HLN series is a line of projection televisions.
20 Vragen Bekijk alle
My picture is very dark
Is dit een goede vraag?
Score 3
1 Opmerking
Serial # B19G3CKL501709L
MODEL # HLS5087WX/XAA
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
hpimidwest, it is possible that it is your bulb.It could mean that your lamp is old (4000-5000hrs) but it could also be your ballast. As the lamp gets older, it requires more voltage to spark or ignite. If you still have a picture, just dark/darker you are a bit in a catch 22 situation. You can buy a new bulb and hopefully that will resolve the issue, but if it does not, you would have to replace the ballast. You may end up purchasing both. There are numerous variation of ballast and bulbs. We'd need the exact model number to help you out further.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
my tv is okay, after a little while, its getting dark, and nothing at all...it has sounds, what is the problem? thanks
door
One of the bulb needs replacement if not calibration. If you are able to take apart, you can test which one is out. If you can't take apart and it's under warranty, get it replaced for free.
Good luck.
Score 1
1 Opmerking:
what bulbs are you talking about
door
no picture has sound wont stay on
1 Opmerking:
drahming 415 you posted a question as an answer to a different question. Your question can now be found here want say on,no picture,has sound
door
Voeg je antwoord toe
hpimidwest zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,784
