Ga door naar hoofdinhoud
De TI-84 Plus Silver Edition is een grafische rekenmachine die in 2004 werd uitgebracht. Hij bevat een USB-poort, vooraf geïnstalleerde software, APPS, opslagruimte en een verwijderbare voor- en achterkant.
Why my calculator is not charging?
When I plugged in the charger, it shows greenlight but still low battery even though I charge it overnight
Is dit een goede vraag?
Score 8
9 opmerkingen
I read on another site that if you unscrew the battery compartment, unwrinkle the cords, it will charge better. I didn't think that would work, but strangely enough, it is charging and actually working. Hope this helps.
door
how do you open the battery compartment though? mine wont open
door
Sarah Durbin you checked this guide?
door
This worked for one of my students. Thanks for the suggestion!
door
but what if you have the one that is color and doesn't run on batteries
door
4 commentaren meer tonen
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
Try using the reset button on the back. That fixed it for me!
Was dit antwoord nuttig?
Score 5
6 opmerkingen:
It worked for me as well!
door
reset button on the back meaning?
door
Using the reset button on the back worked for me too.
door
Where is the reset button?
door
It doesn't work at all...
door
1 commentaar meer tonen
Score 2
1 Opmerking:
It worked! thank you :)
door
Reset your calculator: If you turn to the back of your calculator in the mid-left you will see a small button that says reset.
  • Using a pen (pointy) push it and turn on the calculator again.
If this method doesn't work for you then you might have some other problem.
If your graphing calculator isn't charging and it doesn't take 4 AAA batteries then it works on a block battery that you have to unscrew the 2 screws and unplug it for 10 seconds, plug it back in and tighten the 2 screws and charge it and it will function normally.
Your calculator battery may be reduced in lifespan and it could also be your charging port. You can buy charging ports for TIs and other brand calculator online.
Voeg je antwoord toe
faroukiskandar96 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 72,833
