Ga door naar hoofdinhoud
TI-84 Plus Silver Edition Backup Battery Replacement
Wat je nodig hebt
    1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: stap 1, afbeelding 1 van 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: stap 1, afbeelding 2 van 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: stap 1, afbeelding 3 van 3
      • Push firmly down on the tab located on the back of the calculator near the center.
      • Pull the tab up, lifting it off of the calculator and exposing the batteries.
      Vraag FixBot
      Voeg opmerking toe
    2. TI-84 Plus Silver Edition Backup Battery Replacement: stap 2, afbeelding 1 van 1
      • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
      • Push the positive (+) side of the batteries to remove them
      Vraag FixBot
      Voeg opmerking toe
    1. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: stap 3, afbeelding 1 van 1
      • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
      Vraag FixBot
      Voeg opmerking toe
    2. TI-84 Plus Silver Edition Backup Battery Replacement: stap 4, afbeelding 1 van 1
      • Grab the plate and lift gently upward, to remove the backup battery cover.
      Vraag FixBot
      Voeg opmerking toe
    3. TI-84 Plus Silver Edition Backup Battery Replacement: stap 5, afbeelding 1 van 2 TI-84 Plus Silver Edition Backup Battery Replacement: stap 5, afbeelding 2 van 2
      • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
      • The backup battery is an SR44SW coin cell battery. You can also replace it with a size 357/303 or LR44 battery.
      • Push gently downward until the backup battery pops out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
17 andere personen hebben deze handleiding voltooid.
Agustin
1.047 Reputatie
2 handleidingen geschreven
Cal Poly, Team 11-34, Amido Fall 2013 Lid van Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 Leden
20 handleidingen geschreven
9Gids Commentaar
My son's TI 84 Plus C has a rechargeable battery with a little cord attached to it which is significantly different from the AAA's shown in this Guide!
annualgain - Antwoord Deel
Because it's a completely different calculator.
Ozan Munsuz - Antwoord Deel
Muy instructivo e ilustrativo que permite fácilmente la operación de cambio de bacteria.
Andres Guaty - Antwoord Deel
Do NOT replace the back up battery and the main batteries at the same time! If you do, you will lose all of the calculator’s memory.
Alexander Dombroski-21 - Antwoord Deel
Too late…….. I had about 13000 bytes of programs
Aaron Rueppel - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 150
Altijd: 72,057
