Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone can only charge by 1 type of cable.
My iPhone 6 left 5% and I wanted to charge but it can't! I use 4 different type Apple original Lightning connector and tried both side and it not working. So, I quickly back up my phone, still can back up thru computer but not charging. This happen 6 month ago, I tried to send back warranty, but Apple reject it. So, I started repair it myself. I replace the battery, also replace charging port but still not working. And today, it is 6 months later, I left my iPhone dead for 6 month. I used my another iPhone 6 to charge my running low battery from the old iPhone. I charge till 30% and I put it back to the old iPhone 6. And it turned on again, everything still there. But it still can't be charge. I restore and update it. I tried again using different cables hope to have a miracle. I tried all 4 Apple Original Cable and iPhone said "This cable or accessory is not genuine." I tried to think, "If Apple cable is not genuine so which is genuine?" So I am going to find a cable that is not genuine. I find my old China Lightning connector I bought 2 years ago for my iPhone 5. And it works and start charging! *I bought 3 different type of china cable only works with 1 type*. But the problem is I can only get 5% for 40mins charge. And why can only be charge by 1 cable? What should I do if this cable broken?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The problem is with a charging controller located inside of the iPhone. Looks like it's been fried at some point. It needs to be replaced, but Apple don't provide such service.
Look for specialists in iPhone repair business.
Was dit antwoord nuttig?
Voeg je antwoord toe
Nicholassywong zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,170
