Ga door naar hoofdinhoud
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Vragen Bekijk alle
How can I clean my 1 TB Mac hard drive?
My Mac hard drive is badly cluttered and I suspect lots of junk is accumulated on my drive. How can I clean this Mac safely?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
Best to use some Apps here to do the job. But before you start make sure you have a good backup!
  • I would start off with this: Disk Doctor It will do most of the heavy lifting here deleting your old files.
  • I would then use an external bootable drive to boot the system up from so I could then use Apples Disk Utility to repair the permissions and the disk its self. You may need to run it though a few times to clean everything.
  • The next tool here is a HD drive defrager (not needed with SSD's). It re-connects the file fragments back together as they do tend to get scattered around the disk more so when the disk is full.
The last thing I would do here is clear out any old files so I have at least 1/4 to 1/3 of the disk free. This will minimize file fraging and will offer your system needed swap space.
You may also want to think about upping the RAM to 8GB if it isn't already and review what is running within Activity Monitor. I would be careful here stopping or deleting processes until you understand what it is doing and which app it maybe part of.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
You should try some free tips to clean up & Speed up slow Mac
  1. Use Finder<<Go<<Go to folder<</Library/caches and clear all caches files from it
  2. Use Finder<<Go<<Go to folder<</Library/Logs and clear all logs files from it
  3. Use Finder<<Go<<Go to folder<<Applications and drag unwanted apps, software to trash
  4. Use Finder<<Go<<Go to folder<<Widgets and drag non Apple and sluggish widgets to trash
  5. Drag all useless downloads from Download folder to trash
  6. Send all Duplicate files to trash*
  7. Using Activity Monitor<<Quit unresponsive apps
  8. Empty all files from Trash
  9. Cut down number of apps icon from Desktop as well as Dock
  10. Stop all animation on Mac OS X
  11. Delete Leftovers of Uninstalled applications
Score 1
Disclaimer: as always, backup important files, folders and configurations as needed.
  • I find the easiest, fastest way is to use GrandPerspective. Free, lightweight and been using it for years now with excellent results every time. It shows your drive in a graphical way so you can immediately see which files or folders are occupying the most space on your drive, or any folder you choose. Download from: http://grandperspectiv.sourceforge.net
  • Using Finder track down all "deletable" files you've created or downloaded and move them to the trash (don't delete system files like Library folders and such). Deleting from your home folder should be safe enough.
  • Empty all your Trash cans (from Mail, iPhoto, Finder)
When I use your MacBook for a while, I will find it runs very slowly. At this time I need to clean up its storage space to improve the running speed. Here's how to do this! You can clean up your storage space in a few ways:
1. Clean up the cache
2. Uninstall applications that are not in use
3. Delete old email attachments
4. Empty the trash can
5. Delete large files and old files
6. Delete old iOS backups
7. Erase language files
8. Delete old DMG and IPSW
9. Remove duplicates
10.Organize your desktop
In fact, cleaning up separately according to the above is a very troublesome thing, so I recommend you can use the Mac Cleaner under the iMyMac website to clean up. It combines the above ten functions with one software. This is a piece of software that I have used recently to clean up my Mac.
Just use a mac uninstaller and create a huge of free space by removing unwanted files and folders.
Voeg je antwoord toe
telewormuk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 467
