Ga door naar hoofdinhoud
Vijfde generatie van de Lexus ES luxe sedan.
Headlights keep turning off.
My headlight keeps turnong off on its own while I'm driving. How can I tell if its just a bad bulb or the whole head unit has to he replaced (much more expensive!)? How and what part do I need to replace it with?
Is dit een goede vraag?
Score 3
3 opmerkingen:
I have the same issue. The passenger side or the drivers' side just turns off; every time I brake, one of them turns off. Often, while driving, it just turns off on its own.
door
I have 2014 Lexus ES 350 have the same issue the headlight turn off on passenger side and turn off driver side while on driving at night
door
I have a 2007 Lexus es 350 an when I turn my head lights on the driver side goes out right after turning them on . We changed the fuses but it still does it. What can I do about this?
door
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Are you saying one bulb only turns off and is it the same bulb?
Is your car equipped with HID headlamps?
If it is often what happens is the ballist starts to fail.
Was dit antwoord nuttig?
Check connectors, if they're OK, replace bulb
You should replace the adapter of the headlight.
Voeg je antwoord toe
greenjacket99 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 4,796
