Ga door naar hoofdinhoud
Samsung Galaxy Mega 2 Android smartphone was announced on September 2014.
Camera Error and USB connection
Keep getting "camera failed" error message. Think I've tried everything..factory reset, clearing cache, undtalling flashlights,etc.. Also cant connect to pc via USB cable. Cannot select the "tethering and usb" function..stays blacked out. I need help.
Is dit een goede vraag?
Score 51
2 opmerkingen
might be hardware damage, maybe water damage.
door
I think it's time we all get a new phone
door
Voeg een opmerking toe
10 Antwoorden
Het nuttigste antwoord
Wiping the cache partition did not work till I then pulled the battery and reinstalled...
Was dit antwoord nuttig?
Score 10
8 opmerkingen:
Dear michaelbowerscore1st, thanks for that tip! It worked for me. Sorry, my Samsung. Eternally grateful.
door
Thanks i just pulled battery and it works again.
door
thanks mate , i made an account just to tell you that !
door
This worked. Thank you kindly now!!!
door
omg...thank you soo much it works for me!! Thank you! God Bless you..
door
3 commentaren meer tonen
Here's one more trick you might try:
  • Turn your Samsung Galaxy S4 off and hold Volume Up, Home, and Power keys simultaneously until your smartphone starts to vibrate.
  • Let go of Power key and keep pressing the other two.
  • It will get you into Android System Recovery mode.
  • Press Volume Down to choose wipe cache partition and use Power key to select it.
Alternatively another trick I've used in the past:
  • Connect your device to your computer using a data cable.
  • Go to folder: Computer\SAMSUNG-SGH-I747\Phone\Applidium Image Cache
  • Delete everything in this folder.
  • Go to folder: Computer\SAMSUNG-SGH-I747\Phone\Android\data\com.sec.android.gallery3d\cache
  • Restart your phone.
Score 5
4 opmerkingen:
My computer cant find my phone.
door
Thank you so much! the 1st method is work!
door
Thank you thank you. It worked on my galaxy mega 2.
door
have tried all this , nothing has worked. Screen freezes & goes half pink/purple.
door
Im having the same problem as the OP, and tried the cache partition reset but still getting the camera failed error, and cant connect to my PC through USB. Any other ideas?
Score 2
1 Opmerking:
If this doesn't work for you above, then I would suspect you could be dealing with a hardware component failure. The first and cheapest troubleshooting step is to replace the camera assembly. If that doesn't work, you could try the motherboard assembly.
door
It definitely helped to delete flashlight app and take battery out and restart. Thank you. I now have my camera working
Score 2
Samsung sm g750h Camera fail
Score 1
If your mega2 Camera failed
First your mobile phone
Setting>
Date and time>at automatice date and time>mark making
All you do
Go to camera
Testing
Camera failed resolveing
เครื่องซัมซุง แกแลกซี เมกกา2 มีปัญหา camera failedต้องทำอย่างไรค่ะ
1 Opmerking:
ต้องการคำตอบจากคำถามค่ะ
door
Had the same problem with a failed camera message and PC not recognizing USB connection.
Solution - Turn off the phone > Pull the battery > Hold power button for 3 seconds > Reinsert battery > Turn on phone.
Camera works from lock screen, cannot confirm beyond that.
Camera application is lost.What is doing?
Voeg je antwoord toe
Sam G zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 21,409
