Ga door naar hoofdinhoud
Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
77 Vragen Bekijk alle
Where is the speed sensor?
My 1992 3/4 ton truck 4 wheel drive is throwing a code, 24 speed sensor failure, where do I find this sensor?
Is dit een goede vraag?
Score 2
1 Opmerking
I have a 1995 chevy 4by4 and the speedometer isn't work and it's not shifting into 3rd gear could it be a sensor
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
8 Ball it should be located on the transfer case output shaft.
Was dit antwoord nuttig?
Score 3
It should be located on the driver side of the transmission near the rear where the transfer case meets but on some of them it is on the passenger side.
1 Opmerking:
I do not have 4 wheel drive.
door
At the rear of your transmission on the transfer case just where your drive shaft slides in
Voeg je antwoord toe
[deleted] zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 54
Afgelopen 30 dagen: 259
Altijd: 35,546
