Ga door naar hoofdinhoud
De AirPort Express A1264, die in maart 2008 werd voorzien van een update met 802.11n Wi-Fi-ondersteuning, is een compact en draagbaar draadloos netwerkapparaat.
Fix for AirPort Express A1264
Hello,
I have an airport Express a1264, it sometimes gives me a few seconds a green light, and then a orange one. I think then it's booting. But after 5 seconds it stops. When I try it again, then it isnt showing me any sign of life. Maybe it's the power supply. Please help me.
Kind regards
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
First give this a try: Resetting an AirPort base station FAQ.
You may need to reconfigure the AirPort. Download the AirPort Utility from here: Support downloads
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Hello,
I've done it several times, but the airport is not showing me a light.
I really think it's a hardware failure.
door
Can you access it via the Ethernet connection with your Mac running the AirPort utility?
door
I'm sorry for my late answer. But no, nothing works, it doesn't show up.
door
Ouch! Thats not good ;-{ Sounds like its time for a new unit.
door
Based on your comments on the status LED, most likely, the power supply in the base station has failed.
Ref: AirPort base stations: About AirPort base station status lights (LED)
One possible means to try to revive it would be to perform a "factory default" reset on the base station. You may need to try this a few times. If this fails to solve the issue, you will need to replace your base station.
Voeg je antwoord toe
Diederik De Coninck zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 2,918
