Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Vraag afgerond
glass broken. All else works fine
can I change out just the glass or do I need the Assy.?
The glass is less than $10 and the Assy. Is just under $100
On the repair here. It doesn't show info on the LCD removal.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Jetfixer, sure you can. All you need is an LCD separator and a OCA vacuum laminator and a few other tools. As you can see, unless you have the tools and the experience, I suggest that you replace the complete assembly. Cheapest way to go is to actually let Apple do it for $109.
Was dit antwoord nuttig?
Score 1
of couse you can, but the installation of any new part should be done by a qualified person.
1 Opmerking:
I'm sorry. I was under the assumption we should be able to fix our own stuff. Just looking for a little insight.
door
you can change the glass lens by yourself. v
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 159
