Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
Vertical white lines and red screen after dropping on face
My daughter dropped her 5c on a concrete surface, landed directly on face. There is no visible damage to phone. When she clicked home button, vertical white lines and a colored one appeared and the screen is mostly red. Unfortunately she had it in lock mode and the screen is now unresponsive to swipe. The phone is still functional and receiving calls, texts, and alerts. Someone suggested it may be the LCD is damaged. I'm not techy, but trying to see if this can be fixed as she's been unable to download pics to cloud...not enough storage. We've fixed that now and were hoping the automatic backup would happen as it appears she's connected to wifi. Any guidance or suggestions would be greatly appreciated!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi Marci,
There is nothing you can do except replace the display assembly for now. When the iPhone fell, the display got damaged so badly that it doesn't respond to touch and does not show an image anymore. This indicates that the display is completely useless and should be changed. If further damage did occur, you will be able to tell only after changing the screen.
If you are going to attempt the repair yourself, use this kit to replace the screen assembly as per the steps found in this guide.
If you don't feel up to it, have it replaced at an Apple Store or a good repair shop/technician.
It is a pretty simple and straightforward repair and there is a high probability it'll be all you'll need to do to have it back in working condition.
Good luck!
iPhone 5c Screen Afbeelding
Product
iPhone 5c Screen
$34.99
Was dit antwoord nuttig?
2 opmerkingen:
so I've had a similar issue and replaced the screen. The touch function still does not work. What can I do to diagnose any further damage or issues?
door
If the screen is known good, you probably have a failure on the mother board of the iPhone. It is not uncommon with 5C to suffer from this failure because their housing is flexible and allows the mother board to flex if the housing itself is bent/dropped.
door
Het nuttigste antwoord
Try to disconnect and reconnect the LCD cables
Score 1
Voeg je antwoord toe
Marci zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 8,927
