Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Canon ImageCLASS MF4350d is een alles-in-één kleuren-inkjetprinter die in 2008 op de markt kwam.
Cleaning/ replacing Scanning roller in ADF
How to clean/replace scanning roller in Auto document feeder in cannon image class 4350 printer.( Streaks appear in copies while using Auto document feeder)
Is dit een goede vraag?
Score 2
5 opmerkingen
Very interested answer, but I am new, so can you send me photo or video?? Thanks in advance
door Deel
@batran, almost everyone is new here. What do you mean by "Send me a photo or video."
door Deel
Because I don't know where the sensor is...Tks!
door Deel
optical point of contact with the document and if there is dust than big black streaks.......I don't know where is it???
door Deel
Yes, ba tran has a great question, how do you know where the sensor is??
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
This is a super easy fix. i had this problem and all it took was a microfiber cloth to remedy it. just whipe the scanning surface at the left edge of the scanner with the cloth be sure to get under the plastic feeder too because when you scan with the ADF (auto doc feeder) that small space is the only optical point of contact with the document and if there is dust than big black streaks
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Thank you for your instruct, but I still don't know...where is the only optical point to clean??? Can you take photo to show me please???
door Deel
Please take photo and show me where to clean??? Thank you so much!!
door Deel
I agree, a photo would have been very helpful!
door Deel
Hi @Josh Wilson
Here's a
Here's a video that may help.
Start at about 0:58 seconds into the video.
I realize that it is not for Canon printer but most printer ADFs work the same.
Voeg je antwoord toe
Thiru zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 32
Altijd: 2,484
