Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Microsoft Surface Pro 2 is een tablet/laptop-fusie die in 2013 werd uitgebracht. De Surface Pro 2 is de opvolger van Microsofts Surface Pro en gebruikt Windows 8.1 tot en met Windows 10.
Power button no longer works
Hi
Came to power on my surface today and the power button no longer clicks meaning I can't power it on, would it be possible replace the button?
Thanks
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
6 Antwoorden
Filteren op:
Het nuttigste antwoord
Sorry, I never updated this with the solution that I came up with.
I was never able to get a replacement power button, so I removed the button entirely and there is a direct line of sight from the old power button hole to the ribbon connector on the motherboard. So you can short it with a screwdriver to mimic the button press.
Worked for 2 years starting it every day with a screwdriver across the pins!
Hopefully that helps somebody out.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
thank you for the update. Do you have any picture of it? i have the exact same problem
door Deel
How did you take it off
door Deel
I had the same problem, a clean was enough to get it working again
Afbeelding
unfortunately my my touch was damaged when I opened the screen
Afbeelding
Score 1
2 opmerkingen:
is it work well now?
door Deel
it looks the power botton is soldered to the palstic panel. after take it down is it possible to solder or glue it back?
door Deel
Power button assemblies are available on ebay, but to fix it- you need to completely remove the screen/digitizer- not an easy task and not recommended unless the screen is already broken and needing replacement anyway.
Could someone be more precise as to the model number for the Power button assembly for the Surface Pro 2? I’m having trouble finding it on eBay. Hopefully they’re still available these several years later.
to whoever reads this, I have just discovered that my surface pro2 also has the same issue and the only way I can get it to startup is to hold both buttons and do a hard reboot. I am going to try and put my pro into sleep mode instead of switching off completely and see if I can overcome this problem. I can easily guess that taking it to BestBuy/ Currys uk that it would be too costly. I might have to do a trade in as the self fix option is not suitable or might not work even afterwards. Sorry I could not come up with a better answer.
Having left my surface pro in sleep mode and gone back to it several times, I have been able to either click the mouse or tap the cover to activate it. Hopefully this will allow me to use it without buying another one.
Voeg je antwoord toe
Sam Wildig zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 119
Altijd: 10,774
