Ga door naar hoofdinhoud
How to unlock myphone
hi i have forgot my mobile password , please help me unlock the phone. thanks .
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
1 Antwoord
atish kumar, a hard reset will help you with that.
Steps:
- Make sure that your Samsung S6102 Galaxy Y Duos is Off, And has no SIM or Memory cards are inside.
- Take out its battery for 10 seconds, Then put it in again.
- Press and hold Volume Up + Home Keys, Then press Power.
- Keep pressing the above keys until Samsung logo appears,Then release all keys.
- Wait until you are into Factory reset / System Recovery menu.
- Use Volume Down key to scroll down and select Wipe Data / Factory Reset option.
- Use Power button or Home key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use Power button or Home key to confirm the operation one more time.
- After performing the hard reset, Select Reboot System Now option, And confirm it using Power button or Home key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
Notice: The Hard Reset / Factory Reset operation will delete everything that is saved in your phone's internal memory. From here
Was dit antwoord nuttig?
Voeg je antwoord toe
atish kumar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 859
