120V equipment burn by connected to 240v
HI,
Got a Ninja NJ600 from the States (120v) and wanted to use it in Europe (240v). But, had an accident and got plug in to a 240v power plug directly, and of course it went silent.
I have dismounted the unit and made a number of pictures. Of this the electronic board was burn in one area.
I need to know first, if this information and pictures are enough to get a response?
Second, how I can I fix it?
And last, can I make it 240v capable?
Thank you in advance.
Jacobo PM
Is dit een goede vraag?
5 opmerkingen
I need to replace the MOV in my NJ600 as well, but I'm not sure which MOV to order. Anyone know what the ratings (voltage, current, etc) are for the MOV? There are no visible markings on mine. A part number would help too! Thanks.
door jon.smolders
i have a similar problem, but plugin into a voltage converter on 50hz power in Europe. the MAS blew when powering the device on. This could be a pro blem with the transformer I am using. Panasonic 1500 transforming adapter type that says it is not good for circuits., when i measure the outpuit of the transformer I get 24 volts AC when plugged i nto 220, and my voltmeter will switch to DC for some reason, leading me to believe the panasonic unit somehow must sense a high resistive draw in order to supply the full 110 volts? I understand that the MOS is sensitive to voltage spike, not current spike so I seems like it would work on 50hz? maybe in this system I have used it allows a spike in voltage of some sort. any help would be welcome. I would like to replace the MOS and try with a stable transformer.
door Jeffrey Scott Mastin
we did the same for our ninja coffee maker. but we can’t figure out how to pry open the unit. any ideas?
door Issa Feliciano
Hi I've done the exact same on my ninja blender/food processor
I can send the find a new Capasitor for it
It says 7N271K on it an on the bottom it has 322+
What do I need
Thanks
door Stefan
@Stefan. different blender, different layout. you do want to start your own question and add plenty of images of the damaged components etc. so that we can see what you are seeing.
door oldturkey03
