Ga door naar hoofdinhoud
De zesde generatie van Apple’s draadloze basisstation, uitgebracht in juni 2013. De tower biedt draadloze toegang met ondersteuning voor dual-band en is Apple’s eerste router met 802.11ac-technologie.
Thermal pad replacement comments?
I took my AirPort Extreme apart to give it a clean because it was full of dust. I thought I would remove the heat sinks just for interests sake. When I removed the heat sink I noticed it had a thermal pad between the sink and the Broadcom router chip. I was a little disappointed this was not mentioned in any of the tear downs as I like to replace thermal pads when I pull things apart. I had to put it back together as was but I am looking to replace the thermal pad. Does anyone have any suggestions? Also any suggestions on pad thickness? I was thinking 3mm from memory. IT seemed like a fairly big gap from memory. Any comments greatly appreciated. Also from memory there was definitely only one thermal pad yes?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
These might work for you:
https://www.ebay.com/i/302812527840?chn=...
maybe these
https://www.amazon.com/Fujipoly-Extreme-...
or maybe one of these:
https://www.amazon.com/s/?ie=UTF8&keywor...
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
opinio zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 514
