Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
Is my iPhone four useless?
I dropped my iPhone four awhile ago but altleast a month ago I dropped it again but in the toilet full of water.
It worked after a couple of weeks of sitting in rice.
Now when I go to use my iPhone 4 it turns on. but after altleast 30-40 seconds my iPhone 4 goes black and restarts.
My iPhone 4 only turns on when I plug into a charger.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Lexi, rice is great for cooking but it will not stop corrosion nor will it fix your phone. It is the equivalent of doing nothing. Since it did have an immersion the first thing I suggest doing is to not longer try to turn it on or charge it. It is easily possible that you are shortening out parts on the logic board i.e. the power management IC. If anything, disassemble your phone using these guides. Once you have that done, clean your phone with high grade isopropyl alcohol and this guide. It was written for a 3g but all the points are valid for your phone as well. Once its clean, and you replace the battery, reassemble and re-evaluate for further (if any) damage. Hope this helps, good luck.
Was dit antwoord nuttig?
I have had so much experience with wet phones. Once you have done what previous comment says, I would definitely invest in an otter box or similar case!!! Has saved me more than a few times!
Voeg je antwoord toe
Lexi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 190
