Ga door naar hoofdinhoud
Een HTC-smartphone, ook bekend als de HTC Pico, uitgebracht in oktober 2011.
Mother Board IS Dead
My HTC Explorer fell down from bike, i went to htc care they said my cell needed to replace motherboard, which cost Rs.6500.. phone's present value is 2500-3000 RS. so why should i give 6500 RS... I JUST WANT MY DATA...? ANY HELP FROM YOU ?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
tushar, this will depend on what is broken on the board. The only way to get your data back is by trying a repair. Even if you would replace the board, you will not get your data back. It is stored on the original board.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
thank you... so can you please help me how to repair ??
door
Have you taken a look at the board to check for any visual damage. Anything broken off or any components missing?
door
screen is creck please repair the phone
door
Hi tushar
it seems to be motherboard physically damaged. try to power up the phone with powersupply and connect it to pc via usb cable. if the taken power 10mA to 900mA can assume power part is working, if you already debuging mode on the device try to get data via pc. even if you cannot see anyting on the phone display PC may communicate with PC
Score 1
4 opmerkingen:
even technician said that motherboard is not working...
how to connect it with PC as cell is not even charging...
and screen is off too...
door
charge the cell using extranal charger and connect the device to pc and check wheater device detected or not
door
Bro, motherboard is dead...
phone is not working anyhow...
door
Oops! Try to find a good condition motherboard from eBay only if you loving to HTC exp
Advice: don’t trust the technician and all the things which they said. Better to find your own way to fix the fault.
if you do right thing your fault may solve
if you do wrong things you will have a good lesson
Cheers!
door
Voeg je antwoord toe
tushar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 1,101
