Ga door naar hoofdinhoud
De Skullcandy Air Raid is een draadloze, draagbare Bluetooth-luidspreker die op 15 november 2013 werd uitgebracht en waarmee je muziek kunt streamen vanaf elk Bluetooth-apparaat.
Why wont my device charge?
I have checked my wall outlet and it works perfectly fine with charging other plug-in devices, it just seems to be a problem with my Air Raid. What should I do?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
If the outlet is working and your device is still not charging, you may have a bad USB port. If your device only charges when the plug is held at a certain angle, will not plug in all the way, or has visibly bent/broken pieces inside the charging port, you should replace the USB port. If you have left the Air Raid charging for a long time, but the battery dies quickly after unplugging it, you may need to replace the battery.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
You should try going to Skullcandy Air Raid Troubleshooting for more troubleshooting help
door
Where do i purchase a new battery?
door
@Sasha Nevin, SAME!! IDK what to do about it, but it is really annoying. I've had to use earphones (the ones u stick in ur ear) and was trying to get away from those, however it just won't charge! I also tried charging it through my computer, therefore it still didn't charge
Voeg je antwoord toe
Sasha Nevin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 5,350
