Ga door naar hoofdinhoud
Alles wat je nodig hebt om je iPhone zelf te repareren! iFixit biedt gratis reparatiehandleidingen en demontage-informatie voor elke telefoon, alsook de beste vervangende onderdelen en handigste tools.
36478 Vragen Bekijk alle
Removing OCA bubbles on LCD using autoclave/laminator
Hey all,
Just wondering if anybody with an autoclave/vacuum laminator can tell me how they find it with the results and if they use a press to apply the OCA or just their hands and a roller? I've seen a few advertised but the seller is claiming the autoclave will not remove all bubbles if it's not done with a dedicated vacuum machine.
Any advice is appreciated, thanks
Is dit een goede vraag?
Score 1
3 opmerkingen
David James, I believe that an autoclave is a pressure chamber to sterilize equipment with high pressure steam. Not sure how that will help with a LCD repair. I thought that you would need a vacuum laminator to do a good OCA repair, not an autoclave.
door
it removes the bubbles when the glass has been applied to the lcd/oca. here's an example: http://www.aliexpress.com/store/product/...
a vacuum laminator is better but they are around $2000
door
Sorry, the title is misleading, i've only just noticed.
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Hello, usually the autoclavecan remove vacuum bubbles, but can not remove air bubbles, so you should take care when put the oca on glass or on lcd.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
What can I do to eliminate air bubbles?
door
You can use Autoclave LCD Bubble Remove Machine, it is uaually used for refurbishing LCD screen.
door
How many times can you put it in the autoclave because have bubble When I take the lcd out of the autoclave the bubbles will be 100% gone, then slowly come back
What advice can you give me?
door
Hi brother,
if you want to remove the OCA bubbles , you need use the autoslave.
the autoslave setting reference: time: 15 minutues press: 0.4-0.5mpa temperature: 30
we advice you use the mitsubishi OCA, is easy remove OCA bubbles.
A good OCA and a good aplication of oca is 80% of work 10% laminating and other 10% autoclave in my opinion
Voeg je antwoord toe
David F zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 5,626
