Removing OCA bubbles on LCD using autoclave/laminator
Hey all,
Just wondering if anybody with an autoclave/vacuum laminator can tell me how they find it with the results and if they use a press to apply the OCA or just their hands and a roller? I've seen a few advertised but the seller is claiming the autoclave will not remove all bubbles if it's not done with a dedicated vacuum machine.
Any advice is appreciated, thanks
Is dit een goede vraag?
3 opmerkingen
David James, I believe that an autoclave is a pressure chamber to sterilize equipment with high pressure steam. Not sure how that will help with a LCD repair. I thought that you would need a vacuum laminator to do a good OCA repair, not an autoclave.
door oldturkey03
it removes the bubbles when the glass has been applied to the lcd/oca. here's an example: http://www.aliexpress.com/store/product/...
a vacuum laminator is better but they are around $2000
door David F
Sorry, the title is misleading, i've only just noticed.
door David F
