Video issue vertical distortion strip
MacBook Air 1.6 GHz Core 2 Duo 2GB RAM 80 GIG ATA 10.5.8
Unit has a 1 3/8 " vertical area of distortion from top to bottom in the center of the screen. I don't have the micro display adapter, currently, to check the GPU on an external. Problem persists when booted from optical drive. There is some play in the hinge, more so on the left side. No noticeable change when moving the screen. Some shooting horizontal white lines within the area, more so when it's the active window. Has anyone seen this before?
Is dit een goede vraag?
3 opmerkingen
I found someone else who asked about a similar issue earlier today on an iMac, no responses there either.
Display screen has white stripe from top to bottom
door Andrew Guenther Deel
UPDATE - The unit runs fine on an external. Found this: LED (short for Light emitting diode) is a newer technology in the market. The use of LED over traditional lamp based LCD's eliminates the need for inverter and backlight lamp.
Am still looking for a tear down of the screen.
door mayer Deel
The MacBook Air has an LED screen? I had no idea.
