ps1 Wont read memory card, and not vibrate
I have a psone slim model 101, that wont read mcs and the joystick wont vibrate, i tested others mcs and joystick and nothing, this problem sstarted when I open the console and the button that turn on the laser I used a screwdriver to press the button and the tip fall on the fuse and make a small sparkle, sorry for my english but i think u can understand, i hope u people answer my question
Is dit een goede vraag?
2 opmerkingen
ls92, it could help if you can explain this "I used a screwdriver to press the button and the tip fall on the fuse and make a small sparkle" a bit more. Or you can post some images of the area with your question. This way we could try to determine if you shorted out some component. Use this guide Voeg afbeeldingen toe aan een bestaande vraag to help you with that.
door oldturkey03
I had problems with my PS1 memory cards not reading on my PS1 but ik they're good cause I tried them on my PS2 but I didn't have the screw driver accident I have no clue why they don't work
door Dale morgan
