I forgot the bios password, how do I reset it?
I forgot the bios password on my Asus N56VZ, how do i reset it?
Is dit een goede vraag?
Yes, you can reset your Bios or UEFI password if you forgot it. (works on UEFI based laptops at least... don't know if it will work on everything)
This only works if you can boot into windows (or other OS) ! It will reset you BIOS or UEFI password if you have forgotten it.
- Boot into windows and change the date to 2002/01/02,
- Reboot while while hitting F2 to get into the BIOS / UEFI, when the enter password window appears hit "Alt + r", a "Enter rescue password" window will appear, with 2002/01/02 date showing (if not the code won't work), enter the following rescue password : ALAA4ABA
- Done ! You're in the BIOS / UEFI
- Change back the date and other settings to their correct values in the BIOS / UEFI, save settings, and you're good.
Thanks to https://www.youtube.com/watch?v=NZfFcHtY... for the solution !
Was dit antwoord nuttig?
a bios password is not something one can simply reset, you could compare it to the iphones icloud lock, i would contact the manufacturer and see if they can do anything for you
You could open the motherboard and remove cmos battery. Thanks.
This method has not worked for a long time. On most motherboards, the password is stored on a separate NVRAM chip, so removing power won't clear the password.
mine just remove cmos battery..
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 7,705
2 opmerkingen
does it give you any code when you enter the wrong password for the third time?
door oldturkey03
No it doesn't.
door David Fear
