I see a charging symbol, but the battery percentage is not increasing.
My iPhone 5 was working properly for more than 1.5 years. Now, I'm having a few problems with it. I will explain the problems one by one, after doing all the diagnosis I can on my end:
- When I charge my iPhone, it shows the battery percentage indicator, but the battery percentage doesn't increase.
- The charge indicator will stick on the number that's currently on the display.
- After restarting the phone, I see the battery percentage increase—but this doesn't work every time.
- Sometimes the phone charges properly, but I have to face this issue most of the time.
- When I do a hard reset (home+power button), the battery percentage drops from around 25% to only 8%.
- When I try to connect my phone to my PC, the phone restarts again and again.
- Sometimes, when I use my phone while charging, the battery percentage will not increase.
- When I charge my phone with the battery below 10%, the phone restarts again and again.
- Sometimes, when the battery is totally dead and I try to charge it, the phone won't start, and it will only show the red indicator on the screen.
- I've been facing this issue for the past week. My phone is currently on iOS 7.1.1.
- When the phone gets to 100% charge, it does not show the full charge indicator on the battery.
- I need to unplug and connect a few times to make the iPhone connect to iTunes, but iTunes works fine on the phone.
- The phone has never been repaired before.
- I've tried changing the charger and cables. I've also recalibrated the battery and performed a restore, but that didn't fix the problem.
Is this issue due to a bad battery, or is there some problem with the phone's logic board?
Is dit een goede vraag?
72 opmerkingen
Mine does the same thing but I have a wall plug that lights up when my phone is charging so if I plug my phone in and it doesn't light up I can usually shake my phone a little and then it will light up but today I can no longer get my plug to light up so now I don't have a clue if my phone is really charging or not
door Bethany
Omg my battery says it's charging but it's already 100%. I know it is but it keeps saying it's only 99%. I really need help.
door Cindy
UPDATE TO MY LAST COMMENT:
It SOMETIMES charges to 100% and sometimes it doesn't. I mean, it's fine by me because some people have a problem that it doesn't charge anymore so if it is dead then it will never be able to work again. I'm just happy it can charge.
door Cindy
i have iphone 4s, when i was update my phone ios 8, after this my phone is not charge properly, bacttery backup is very less, battery charge up to 65% only. please suggest what i can do for this. please help me.
door rohith
My iPhone 5c won't charge properly it'll show the charging thingy on the screen but won't turn on. And when it does turn on it'll go from 8% to 1% and die instantly and it will keep doing this for hours. Then when it does charge properly the battery dies really fast. Help?
door beth williams
67 commentaren meer tonen
