Ga door naar hoofdinhoud
De HTC One SV is een slanke 4G LTE-geschikte Android-smartphone die fantastisch klinkende Beats Audioâ„¢ combineert
Why does an error message keep popping up?
An error message saying my dialer has stopped working keeps popping up. It gives you an option of send a report or don't send and it pops right back up after you pick one of the options.
I had my carrier factory reset it and it did not help. Please help save my phone.
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
4 Antwoorden
Filteren op:
The issue you are seeing is call "force closing".
If your phone is stock, that is not rooted, then chances are a third party app is causing the problem. If it happens after a factory restore, with no third party apps installed, then you just need to clear the cache.
http://forums.androidcentral.com/verizon...
That's a guide on clearing your cache. You will have to redownload your apps but that should fix it.
Was dit antwoord nuttig?
2 opmerkingen:
i cant clear my cache in htc one m8 due to marshmallow update
door
? Marshmallow has nothing to do with the stock recovery. You absolutely can still clear your cache after the update.
door
Go to settings then go to apps after that go to running apps and uninstall up date on input sense
I am experiencing the same issues with many apps. Email, clock, dialer etc. I am unable to get into settings.
Same error.
What other options are there?
SOFTWARE updating problem
Voeg je antwoord toe
Nicole Hallett zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 11,050
