Ga door naar hoofdinhoud
The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
20 Vragen Bekijk alle
replace non working camera
Internal camera not focusing. Two thread size purple haze across image on rear facing camera. Unable to focus. Front camera clear. Phone dropped often. No lense damage visible. No cracks visible. Purple haze looks like internal cracks?
Is dit een goede vraag?
Score 6
4 opmerkingen
not working camera
door
Yes it's. My BlackBerry camera has stopped working more than a year.
door
happy if it be fixed
door
I got it fixed but now it captures low quality images
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
frank, I would download the BlackBerry Virtual Expert from BlackBerry World or go into Help and select Testing, which will allow you to use BlackBerry Virtual Expert without downloading it. With that you can test each feature in your BlackBerry Z10. Check both of the cameras with that. Also make sure that your software is updated. If your camera should be faulty use this teardown to see what is involved in changing it. The camera is not very expensive and can be purchased from places like this as well as many others. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
frank zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,156
