Ga door naar hoofdinhoud
Dit in november 2013 uitgebrachte model uit de HP 2000-serie is het perfecte apparaat voor mensen met een beperkt budget die niet willen inleveren op prestaties.
Why is my computer very loud?
My laptop has been running fine since I bought it a few months ago but all of a sudden it has started getting very loud and hot while on. The fans have been running nonstop. Is there anything I can do so that it will quiet down?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Conor Most, you will have to find out why it does that. Check your computer resources and see what the total demand is. Make sure that your laptop has unobstructed airvents. Make sure that those vents are clean. If all that is normal you will have to disassemble your computer and take a look at the Fan. I would replace it for sure. Check the heatsink and assembly and replace the thermal paste. download the service manual from here Page 73 will tell you how to replace all that . Hope this helps, good luck
Was dit antwoord nuttig?
Score 3
It's under warranty, let HP fix it or you'll void that warranty!
Voeg je antwoord toe
Conor Most zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 764
