Ga door naar hoofdinhoud
Een smartphone in phablet-stijl met stylus, in 2013 uitgebracht door Micromax Mobile.
Recover data from A240 internal memory
My phone is not getting switched on. i tried many things
power btton+ low volume key etc.
service centre have said to rplace the motherboard.
i need my data badly from internal memory. service centre is not helping. need some one immediate help.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Data is proprietary (you won't be able to read it). If you can pull the SSD the phone center should be able to mount it in a new phone. If not go up the line until you find someone who can help you.
If this answer is acceptable please remember to return and mark it.
Was dit antwoord nuttig?
Score 1
vib, the data is stored on t\some hardwired NAND memory chip. Unless you can build a NAND reader and have the software to access the chip, there is no way you can get to the data. Some data recovery centers do have that equipment, but it is very costly to use their services. Sorry, but a normal DIY'er and normal repair shop will not have access to that method. Hope this helps, good luck
Score 1
Voeg je antwoord toe
vib zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 1,200
