I need a Part ID
I couldnt get this page to let me post a photo, but,
I need someone to give me a PART ID.
The part i need is for a IPad 2 CDMA Verizon
The part is located in the black antenna window.
In that window there is the GPS & the left sideCellular Antenna. Now, under the cellular antenna(i think is the right one) in the black plastic cupped out area the antenna sits in, at the end of it, there is a very small flex cable in the that is glued down, and has a short piece of that flex cable that sticks out through the slot in the frame. The end of the flex cable has a copper connector that slips into a flex cable female clasped flex or ribbon cable. The other end looks like a resistor. Can anyone tell me the name of that very small piece of flex cable is? I need to ID the part to order it, i can't find it listed anywhere.
Is dit een goede vraag?
Do you see the item in this picture, http://d3nevzfk7ii3be.cloudfront.net/igi...
door eman05
Use this guide to add images Adding images to an existing question
door oldturkey03
