Ga door naar hoofdinhoud
Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
80 Vragen Bekijk alle
Transmission fluid—how many quarts to fill?
How many quarts of transmission oil for my 2005 Ranger 4WD?
Is dit een goede vraag?
Score 3
2 opmerkingen
its a 1992 ford ranger 5 speed
door
patsymiller0, 1992 Ford Ranger 5 speed manual transmissionApprox 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
https://www.youtube.com/watch?v=AC8lhIcK...
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Raleigh, Ford says that the transmission holds 10 quarts on two-wheel drive models and just under 10.5 quarts for four-wheel drive models for a complete change.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
08033530020 Mr ola
door
Four wheel drive
door
@Olayanju Suraju what make, model, year?
door
Uses less if you don't drain the torque converter.
Score 2
2 opmerkingen:
Well how manny qrts is less if u dont drain the TC??
door
Generally the tc holds about 4-5 quarts
door
Dit antwoord was oorspronkelijk aan een andere vraag gericht.
According to the Owner's manual :
2005 Ranger Auto Transmission Fluid - use Mercon V
4x4 with 3.0 and 4.0 engines use 10.3 Qts (9.8L)
Note the 4x2 uses 9.9 Qts (9.4L) with the 2.3L engine and 10.0 qts (9.5L) with the 3.0/4.0 engine
Score 2
1 Opmerking:
2005 Ranger 4x4 with 3.0L or 4.0L engine takes 10.3 qts (9.8L)
Use Mercon V ATF
see page 233 of manual
https://www.fordservicecontent.com/Ford_...
door
Raleigh /patsymiller0, If a manual tranny, Ford Ranger 5 speed manual transmission Approx 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
Score 2
1 Opmerking:
How many liter atf for my ford everest 2005 model automatic transmission
door
Voeg je antwoord toe
Raleigh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 69
Altijd: 55,327
